Hello Forum, we have a flight of steps which we need to wrap artwork too, Project is getting me close to what we need, but some areas look a little stretched, specifically on the risers of the steps, the treads look ok. What would be the best method to wrap the artwork to the steps keeping the curve work as intended. (I’m not a GH user, native Rhino) tia
Artwork To Surface Flow.3dm (18.2 MB)
you can rebuild the entire stair surface into one surface then use flow, but this is a design decision you have to take if you simply want the artwork to show linearly, project does not work of course that will just stretch the parts in that area.
here i simply merged all the surfaces together then unrolled that then merged all copplanar surface on the unrolled surface and used flow along surface, it actually worked out without hick ups.
Artwork To Surface Flow.3dm.zip (16.3 MB)
@encephalon nice one bud, yes it looks like flow along surface is the way to go, much appreciate the input, cheers
