Array object for python script?
i wanted to create an array using python script
so how can i give multiple values to the i = x-axis points for example like i = ( 2 , 4 , 6 , 8 )
so a = rs.AddPoint(0,i,0) … there by creating 4 different points?
Hi Andrewsthekkathsachin
I’m not an expert in PY but maybe you could use the “range” command in a “for” loop
but then it will be continuous points like …1,2,3,4,5,6,7,8
but i want points with intervals like 2,4,6,8,10,12
for i in range(0, 4):
    rs.AddPoint(0, i * 2, 0)
the first time through, i = 0
the next time through, i = 1
it will do that until you reach 4 (the end number for range)…
for the point’s Y coordinate, it’s i * 2
which will make the even number sequence.
[edit]-
just realized this is a Grasshopper question…
so maybe something like this:
That would be:
range(0,13,2)
range() has three parameters:
range(start,stop,step)
