Area Distribution script for atrium design
We are looking to distribute circa 800m2 of void throughout our upper floors of building and are wanting to test a variety of proportions and distribution. I’m keen to explore a script that can somewhat randomise the iterative process. I have some Grasshopper experience but am unsure on how to structure this script, particularly how to randomise the distribution of void between floors.
I imagine it might involve setting up some curves with sliders to control area distribution. The rest I am unsure on how to proceed. If anyone is able to suggest some dialogues I might be best to try that would be much appreciated.
I attach a crude sketch of the proposed void distribution below (the zone of the building in which the voids will appear is roughly 7.5m wide and 70m long.
Hello
not knowing Grasshopper is OK, as you seem to be an architect I think you must begin by some rules that you will have to follow if you were doing it by yourself.
I understand you want to make holes in the floor of each level except ground floor
Holes must have a surface near 40% of the surface
How many holes per level
Size limit of holes (width, length)
Do you let some passage for people ?
At the end what are you trying to optimise ? Luminosity …
So before jumping in Grasshopper try to make an algorithm of what you want.
