Thanks. I used the link that @DavidEranen provided earlier in this thread. It’s a big file which is why I thought it would be good one to test.
If you can run Rhino 8, then you meet the minimum system requirements. We upped the required Mac OS requirement for Rhino 8.
10.15 is the new minimum for V8
https://mcneel.myjetbrains.com/youtrack/issue/RH-62207
In general, if you can’t update to the latest OS then there is probably a good reason. I would assume Metal support is one of those reasons.
