Annual wind comfort
in (Annual wind comfort) component for NEN8100 criteria most of the out put is 6 index= dangerous which happens when wind speed =15 m/s when i checked (Wind Factor Annual) for all 8760 hours the w
ind speed didn’t exceed 11 m/s
annual wind comfort_Davenport.gh (53.0 KB)
Although most of the wind values do not exceed 15.1 m/s, the wind comfort component still highlights most sensor points as dangerous areas using the Davenport criteria. I attempted to create a Python component myself to apply the Davenport criteria to each sensor point so i ended up with two different graphs. Could anyone check it, please ?
did you ever figured it out? I have a similar situation and i am not sure if i can ‘believe’ the output generated by the native solution as demonstrated in the template example. When I use your code the results are indeed different
