Rhino Render (Cycles) is not using the GPU (AMD Vega 64), although the graphic card is selected in the Cycles tab under Options. Both Task Manager and GPU-Z report 0 activity on the GPU.
The raytracing viewport states OpenCL is still compiling.
Running _RhinoCycles_ListDevices states that 2 devices are available and the GPU is number 1
I also checked the xml settings file and the GPU is set as the rendering device. Then I assumed the issue was caused by AMD ProRender plugin so I removed it but the problem remains. I’m lost to what the cause may be. Could this be caused by the AMD driver? I’m using the latest AMD Pro Edition 22.Q4.
Here is my SystemInfo:
Rhino 7 SR26 2023-1-9 (Rhino 7, 7.26.23009.07001, Git hash:master @ 92abcf7c453c78a236526390d91d0ac1f6779143)
License type: Educational, build 2023-01-09
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX Vega (AMD) Memory: 8GB, Driver date: 10-25-2022 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 22.20.27.07.221025
> Accelerated graphics device with 7 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 10-25-2022
Driver Version: 31.0.12044.3
Z-Buffer depth: 24 bits
Total Video Memory: 40636 MB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp "VisualARQ"
C:\Users\Filipe\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp "SpeckleConnectorRhino" 2.10.4.0
D:\PROG_ORIGINAIS\Rhino_Plugins\elefront422\elefront421\ElefrontProperties.rhp "ElefrontProperties" 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp "Tibidabo"
C:\Users\Filipe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp "SubstanceImporter" 2.0.3.0
C:\Users\Filipe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.5.3\AMDDenoiser.Windows.rhp "AMDDenoiser.Windows" 0.5.3.0
C:\Users\Filipe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp "IntelDenoiser.Windows" 0.6.4.0
C:\Users\Filipe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Karamba3D\2.2.0.171\Karamba3D_LicensePlugin_Rhino7.rhp "Karamba3DLicense"
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.14.2\Pollination.RH.Loader.rhp "Pollination.RH.Loader" 1.14.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.26.23009.7001
C:\Users\Filipe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp "RPC"
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp "AnimationTools"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
