Aligned dimension gone?
please dont open several identical topics
Sorry but the website didn’t respond
Met vriendelijk groet
Caddrawings/3D-works
Hi @Berto_Terpstra
You’ll have to give us a bit more to go by than “Aligned dimension gone”. Is the command gone? Are the aligned dimensions you already made gone? Are they missing from your PDF? Or your DXF? Or did you accidentally misplace your aligned dimension and now ask for us to help you find it? Also: Run the SystemInfo command in Rhino and post the full resulting text here.
HTH, Jakob
