Adjustable blend curve request
Hey rhino community
Is is possible to to link the adjustable curve blend values and have sliders like the surface blend option.
I constantly find myself having to make surfaces, blend them then extract the curve I desire.
This would make one user very happy indeed
Regards Jahn
Hi Jahn - the sliders are the equivalent of moving the blend curve handles from the second point in from the end (the ‘tangent’ point) . Since there are only two on a curve it should amount to the same thing, though without for the numbers - is that the key?
Pascal
Currently you can not link the control points on the curve blend to behave at the same adjustment proportion both ends .
I use the surface blend to make my curves as it gives a value I can apply to other surfaces to keep consistency in the shapes
Jahn
press shift while moving the cp to keep same proportions on both ends, the factor is a problem yes. Ideally the blend factor of 1 should be close to equally spaced.
Ahhhh!
That’s solved half the problem nice to know- Still the factor of blend would be nice to allow conformity in shapes.
Cheers
You can also enter numbers once you’ve started ajustment…
_
c.
Hi Clement - This sets a distance but does not correspond to the slider numbers on BlendSrf, if I understand what you meant.
Yep, i know. Would be nice to enter the factors somehow.
_
c.
