Adding attributes to a rhino3dm.Point3d
Using rhino3dm in python 3.7 I am trying to find a way to add attributes to a Point3d or find a work around since the point doesn’t have a way to add attribute from the rhino3dm.ObjectAttributes class.
Goal
  • add a point to specific layer, for example: model.Layers.AddLayer(‘low_stress’, (190, 255, 72, 255))
I have instantiate an ObjectAttributes Class with the hopes of placing all the attributes under this value:
low_stress_attr = rhino3dm.ObjectAttributes()
I am running through my point list to find specific points that have a stress load associated and based in the code below:
    for i in range(len(pts)):
        if stress[i] < 50:
            pt = rhino3dm.Point3d(pts[i][0], pts[i][1], pts[i][2])
            new_pt = model.Objects.AddPoint(pt)
The problem
  • trying to add an attribute to the point so that its display color is a value or if I can take all the points in new_pt and add it to a specific layer that I can denote.
Any guidance would be helpful
see if these examples help
import System
from Rhino import *
# Create a new point with custom attrs.
doc = RhinoDoc.ActiveDoc;
attrs = DocObjects.ObjectAttributes()
attrs.LayerIndex = doc.Layers.FindName('Layer 01').Index # assuming you have a 'Layer 01'
attrs.ColorSource = DocObjects.ObjectColorSource.ColorFromObject
attrs.ObjectColor = System.Drawing.Color.Red
pt_id = doc.Objects.AddPoint(Geometry.Point3d(1.0, 2.0, 3.0), attrs) # note this overload, which takes object attrs in the second parameter
doc.Views.ActiveView.Redraw()
# Get the existing point and modify its attrs.
obj = doc.Objects.Find(pt_id) # we have this ID from above, otherwise you would need some other way of getting it
attrs2 = obj.Attributes
attrs2.ColorSource = DocObjects.ObjectColorSource.ColorFromLayer
obj.CommitChanges()
This worked for me:
        Rhino.Input.Custom.GetString gs = new Rhino.Input.Custom.GetString();
        gs.SetCommandPrompt("Name of curve: ");
        gs.AcceptNothing(true);
        gs.Get();
        ObjectAttributes objAtt = new ObjectAttributes();
        objAtt.Name = gs.StringResult();
        doc.Objects.AddCurve(iso_curve, objAtt);
        doc.Views.Redraw();
Awesome thanks, thats what I was looking for. The **import *** didn’t bring in the librarys so I used:
    from Rhino import RhinoDoc
    from Rhino import DocObjects
    from Rhino import Geometry
and it seemed to work fine in Python 3 with rhino.inside python using these packages:
    import rhinoinside
    rhinoinside.load()
I also replaced doc = RhinoDoc.ActiveDoc; with:
doc = RhinoDoc.CreateHeadless("")
to instantiate a defult document
and to write the file I just used:
doc.Export(rhinofile)
Thanks, it took a while but I got the result that I was looking for.
