I’m trying to update a block via python. When I run the test code below, the block only updates as long as none of the newobj are blocks. I want to nest the selected blocks into the updated block, but it fails. There is not error or warning or anything. The block just doesn’t update.
block = rs.GetObject("Block", 4096)
blockname = rs.BlockInstanceName(block)
newobj = rs.GetObjects("New Objects")
rs.AddBlock(newobj,(0,0,0),blockname,True)
dale
(Dale Fugier)
January 31, 2019, 10:38pm
2
Hi @kyle_faulkner ,
In this case, it may be easier to just script the _-Block command.
– Dale
Thanks Dale.
I replaced
with
rs.Command('-Block 0,0,0 "{}" Yes _Enter _Enter _Enter'.format(blockname))
and that seemed to work.
Is this a bug that’s causing the AddBlock() method to fail?
dale
(Dale Fugier)
January 31, 2019, 11:56pm
4
No, just a limitation with Rhino.AddBlock. Creating nested blocks take a bit more work than this simple function can handle.
Here is a sample of creating a nested block in C#. You can adapt this to Python if you want.
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinocommon/cs/SampleCsCommands/SampleCsCreateNestedBlock.cs
– Dale
