Is it possible to add third-party dll as reference while developing plugin for rhino5.0(64bit)? - Grasshopper (grasshopper3d.com)
I want to use the NetMQ package in a grasshopper plugin, it unfortunatelly does not work right now.
I guess I am missing something obvious from the documentation.
Can someone please help with this?
Thanks in advance
NetMQ example code (taken from README) added to default “ASpi” / “archimedean spiral” component’s SolveInstance method.
Also read: Load external library - Grasshopper Developer - McNeel Forum, Rhino - Your First Component (Windows) (rhino3d.com), but they didn’t help for the problem.
Memory load is disabled in Grasshopper developer settings
Same happens when I try to use it from a C# script component (using statements are added):
Version 7 SR16
(7.16.22067.13001, 2022-03-08)
Commercial
Edit:
NetMQ file is not blocked
