I have new problem
In the DlgSampleTexutre.cpp
I add code to modify the scale of the bitmap texture.
//Modify Scale
const ON_Brep* Brep = ON_Brep::Cast(myObj->Geometry());
ON_BrepFace* F = Brep->Face(0);
ON_Interval u_dom, v_dom;
const ON_Surface* Sur = *Brep->m_S.At(0);
u_dom = Sur->Domain(0);
v_dom = Sur->Domain(1);
ON_Curve* uCrv = Sur->IsoCurve(0, v_dom.Mid());
ON_Curve* vCrv = Sur->IsoCurve(1, u_dom.Mid());
double len0, len1;
uCrv->GetLength(&len0);
vCrv->GetLength(&len1);
delete uCrv; delete vCrv;
ON_Mesh* mappingMesh = F->Mesh(ON::render_mesh)->Duplicate();
ON_2fPointArray Texs = mappingMesh->m_T;
for (int i = 0; i < mappingMesh->m_T.Count(); i++)
const ON_2dPoint* p2d = mappingMesh->m_S.At(i);
ON_2dPoint Pnt; Pnt.x = p2d->x; Pnt.y = p2d->y;
double x = Pnt.x;
double y = Pnt.y;
double tx = (x - u_dom[0]) / u_dom.Length();
double ty = (y - v_dom[0]) / v_dom.Length();
tx /= m_ScaleX;
ty /= m_ScaleY;
ON_2fPoint* p2f = Texs.At(i);
p2f->x = float(tx);
p2f->y = float(ty);
mappingMesh->m_T = Texs;
CDES_TextureMapping DES_TextureMap;
DES_TextureMap.SetCustomMeshMapping(*myObj, *pDoc, mappingMesh);
But I found, the scale of the bitmap texture be changed on the firs time value setting, if I change the value of the scale again, the scale of the bitmap texture doesn’t change.
Could you help me to check the program?
PS:
We need to use above code to change the scale of the bitmap texture.
The project, I compile on Rhino6.
DESNewSample.zip (110.3 KB)
In DESNewSample.zip there are
checkmat small.jpg and my project
