Add Curve.PointAtMid() to RhinoCommon?
I might be missing something here and I knwow this has been discussed earlier.
https://discourse.mcneel.com/t/curve-middle-point/18453
Curve Middle Point
As far as I know the only way to get the midpoint of a curve is to use curve.PointAtLength(curve.GetLength() / 2), correct - at least this is what I do.
Would it maybe make sense to add a property to the Curve class, e.g. PointAtMid? At least for me it would save a lot of typing. Even though I could build a small method in my toolbox I always think it would be faster to have this in RhinoCommon and wonder why this is not available there.
Thanks,
T.
I think you can use curve.PointAtNormalizedLength(0.5), not sure if you’d say that’s simplier though.
@Lukxf
This only works with straigth lines, very well described here by @menno.
So I assume the “easiest” way is curve.PointAtLength(curve.GetLength() / 2).
I think he speaks of parameter “t” not of the length along the curve
The documentation is clear
if it doesn’t work it is a BUG.
@laurent_delrieu yes, agreed.
Still this method will be a bit of typing if I am not wrong.
curve.PointAtNormalizedLength(curve.GetLength() / 2)
As distance is normalized [0, 1] you MUST use 0.5 to be on the middle.
curve.PointAtNormalizedLength(0.5);
But yes something like
curve.PointAtMiddle;
could make sense, as it was done in Grasshopper.
Long time ago there was just tha component. It that was quite hard to discover, I found it after some months!
And as it was quite just used for special case they added this one.
@laurent_delrieu
Allright, I have to admit I did understand PointAtNormalizedLength quite the wrong way. But I am relieved because it makes me sleep better :slight_smile:
I also came across the grasshopper component quite late and that acutally was the reason I always wondered if there is an equivalent in RhinoCommon.
Thanks @laurent_delrieu for clarifying for me!
@tobias.stoltmann these blog posts by @DavidRutten are good for explaining curve parameters:
Hi @tobias.stoltmann,
Does this help?
import Rhino
import scriptcontext as sc
def __normalized_pointat(curve, s):
    pt = Rhino.Geometry.Point3d.Unset
    if curve and s >= 0.0 and s <= 1.0:
        rc, t = curve.NormalizedLengthParameter(s)
        if rc:
            pt = curve.PointAt(t)
    return pt
def test_curve_midpoint():
    filter = Rhino.DocObjects.ObjectType.Curve
    rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select curve", False, filter)
    if not objref or rc != Rhino.Commands.Result.Success:
        return
    curve = objref.Curve()
    if not curve:
        return
    # start point
    pt = __normalized_pointat(curve, 0.0)
    if pt.IsValid:
        sc.doc.Objects.AddPoint(pt)
    # mid point
    pt = __normalized_pointat(curve, 0.5)
    if pt.IsValid:
   # end point
    if not curve.IsClosed:
        pt = __normalized_pointat(curve, 1.0)
        if pt.IsValid:
    sc.doc.Views.Redraw()
if __name__ == "__main__":
– Dale
