Add CheckBox to GroupBox header
Hi @all,
i would like to add an Eto.Forms.CheckBox to the Header of an Eto.Forms.GroupBox but have no idea how to do it. The purpose is that the CheckBox then enables/disables some content of the GroupBox. Is it possible with Eto any Python ?
thank you,
c.
How about something like this?
– Dale
Hi @dale, that is close…
is yours a CheckBox followed by a Rhino.UI.Controls.LabelSeparator ?
thanks,
c.
Hi @clement,
The panel uses an Eto.Forms.CheckBox and a Rhino.UI.Controls.Divider.
I’ll let you do the Python port.
class CheckBoxSeparator : Panel
  /// <summary>
  /// Public constructor
  /// </summary>
  public CheckBoxSeparator()
    CheckBox = new CheckBox();
    m_divider = new Divider();
    Content = new StackLayout
      Orientation = Orientation.Horizontal,
      VerticalContentAlignment = VerticalAlignment.Stretch,
      Spacing = 2,
      Items =
        CheckBox,
        new StackLayoutItem(m_divider, true)
  // The divider or separator
  readonly Divider m_divider;
  /// <summary>
  /// Gets the checkbox
  /// </summary>
  public CheckBox CheckBox { get; }
  /// <summary>
  /// Gets or sets the text of the checkbox
  /// </summary>
  public string Text
    get => CheckBox.Text;
    set => CheckBox.Text = value;
  /// <summary>
  /// Gets or sets the color of the line separator
  /// </summary>
  public Color Color
    get => m_divider.Color;
    set => m_divider.Color = value;
– Dale
Hi @dale, thank you. That is a possible workaround but i still would like to know if it is doable with a GroupBox header. I managed to access the header of a GroupBox and it kind of “accepts” a CheckBox like this:
 self.m_checkbox = Eto.Forms.CheckBox(Text="MyCheckBoxText", Checked=True)
 self.m_groupbox = Eto.Forms.GroupBox(Text="MyGroupBoxText")
 self.m_groupbox.ControlObject.Header = self.m_checkbox
grafik
but it doesn’t show the CheckBox instead of the header (label), instead it justs writes out “Eto.Forms.CheckBox”. There seems to be a way with wpf but i have no clue how to do the same in pyhon.
_
c.
Try this instead:
self.m_groupbox.ControlObject.Header = self.m_checkbox.ControlObject
Do note this means it will only work on Windows.
Hi @curtisw, i’m attaching the sample script here, it gives me an error and asks to first perform some kind of pre-division…
SampleGroupBox.py (1.7 KB)
This would be OK once it works.
thanks,
c.
Ah yes, this should work instead.
self.m_groupbox.ControlObject.Header = self.m_checkbox.Handler.ContainerControl
Thank you @curtisw and @dale, it works!
grafik
_
c.
Thank you for helping me :grinning:
