Accurate Cycloid
Has anyone got one in Rhino format ? or know how to generate the curve within Rhino.
Im not sure if this is what you want, and it is only an appox as it steps but:
Cycloid.gh (7.7 KB)
Thanks Tom and Richard, I don’t have grasshopper so wasn’t able to test yours. Richard I was thinking yours would be pretty spot on but as you commented it is coincidental. When I scaled and added numbers to it, the error is significant. I was very surprised as my friend supplied a mathematical cycloid (red curve) that had me scratching my head. The purple curve is mine generated by interpolation of points and corresponds quite well though curvature analysis shows it has some kinks where it transitions to vertical. Richard your curve is smoother, but flawed. If nothing else, Thank You both for confirming my own work, which I doubted.
Bill do you have the rhinoWIP, should have GH inside it?
I have baked the GH model but if you scale it then the accuracy will be lost?
Cycloid.3dm (18.3 KB)
Thanks Tom, just checked the numbers direct from your 3DM, and scaled, it has error too, but could be attributed partly as faceting. Again it helped to confirm my approach and numbers. The gap should always be the circumference of the circle that sets the height, as a fast rule. Generating accurate cycloids is a lot harder than it looks. Fortunatley once you have it, it should just scale within Rhino for each diameter, I shall see.
Again many thanks to you both for responding.
Cycloid2.3dm (35.7 KB)
Was just in the process uploading one at the scale you are using
Just curious why you didn’t use an Interpolate Curve component instead of a polyline? --Mitch
No good reason, I just though it might distort the curvature more than facating
Can confirm that interpolated curve is more accurate and scales accurately within Rhino. This had been bugging me for a couple of days.
Thanks Richard, my friends curve was an SVG file which didn’t translate properly. We have since confirmed a correct mathematical curve against my point generated curve and they are an exact match, removing my doubts about how I generted my own cycloid curve.
For the record, the mathematical curve had 630 points, the Rhino interpolated curve 15.
The previous GH file was not able to produce non ordinary cycloids (where the reference point is not on the circle), plus it had a bug in the code where sin and cos functions were swapped, here is a refined version
Non-Ordinary Cycloid .gh (10.2 KB)
