I have a GH component that, if I run it on multiple breps with parallel processing enabled in Release mode - but not in Debug -, raises an AccessViolationException after Brep.Split.
Is it possible that this has something to do with the GC.KeepAlive(cutter); call inside Brep.Split?
Is there any obvious workaround for this behavior? At the moment, this exception basically prevents us from being able to produce Release builds. Unfortunately, disabling multithreading for the component is also not an option because the performance impact is too severe.
I can provide a sample file and the memory dump, if necessary.
The component code is the following (minimal example):
protected override void SolveInstance(IGH_DataAccess da)
Brep brep = null;
if (InPreSolve)
da.GetData(0, ref brep);
var task = Task.Run(() => ComputeResult(brep), CancelToken);
TaskList.Add(task);
return;
if (!GetSolveResults(da, out var result))
result = ComputeResult(brep);
da.SetData(0, result);
private bool ComputeResult(Brep brep)
var box = brep.GetBoundingBox(true);
var planes = new[]
new Plane(box.Center, Vector3d.XAxis),
new Plane(box.Center, Vector3d.YAxis),
new Plane(box.Center, Vector3d.ZAxis)
var planeSurfaces = planes.Select(p => PlaneSurface.CreateThroughBox(p, box)).ToList();
foreach (var plane in planeSurfaces)
var pieces = brep.Split(plane.ToBrep(), 0.001);
if (pieces.Length != 2)
return false;
// Any call accessing one of the two split Breps causes the exception
var isValid = pieces[0].IsValid;
return false;
An extract of the memory dump shows the following:
* Exception Analysis *
DEBUG_FLR_EXCEPTION_CODE(80004003) and the ".exr -1" ExceptionCode(e0434f4d) don't match
MethodDesc: 00007fff516c7620
Method Name: HelloGrasshopper.TestComponent.ComputeResult(Rhino.Geometry.Brep)
Class: 00007fff516b9ab8
MethodTable: 00007fff516c7698
mdToken: 0000000006000012
Module: 00007fff516c62e0
IsJitted: yes
CodeAddr: 00007fff51c2f040
Transparency: Critical
Source file: C:\Users\Thomas\source\repos\HelloGrasshopper\TestComponent.cs @ 80
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Analysis.CPU.mSec
Value: 6405
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 12394
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 343
Key : Analysis.Init.Elapsed.mSec
Value: 7336
Key : Analysis.Memory.CommitPeak.Mb
Value: 253
Key : CLR.BuiltBy
Value: NET481REL1LAST_C
Key : CLR.Engine
Value: CLR
Key : CLR.Exception.System.AccessViolationException._message
Value: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Key : CLR.Exception.Type
Value: System.AccessViolationException
Key : CLR.Version
Value: 4.8.9075.0
Key : Timeline.OS.Boot.DeltaSec
Value: 63210
Key : Timeline.Process.Start.DeltaSec
Value: 49
Key : WER.OS.Branch
Value: ni_release
Key : WER.OS.Timestamp
Value: 2022-05-06T12:50:00Z
Key : WER.OS.Version
Value: 10.0.22621.1
Key : WER.Process.Version
Value: 7.23.22282.13001
FILE_IN_CAB: Rhino.dmp
NTGLOBALFLAG: 0
PROCESS_BAM_CURRENT_THROTTLED: 0
PROCESS_BAM_PREVIOUS_THROTTLED: 0
APPLICATION_VERIFIER_FLAGS: 0
CONTEXT: 000000e0c15fda80 -- (.cxr 0xe0c15fda80)
rax=0000000000000000 rbx=00000278813eb3f0 rcx=0000000000007700
rdx=00000278d1ff9590 rsi=00000278d18719f0 rdi=00000278d140f1a0
rip=00007ffea66c133e rsp=000000e0c15fe230 rbp=000000e0c15fe330
r8=00000278cbcfa140 r9=0000000000000088 r10=00007fff7e6f0000
r11=000000e0c15fe220 r12=0000000000000229 r13=0000000000000120
r14=0000000000000229 r15=0000000000020670
iopl=0 nv up ei pl nz na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010206
opennurbs!ON_Brep::IsValid+0xd0e:
00007ffe`a66c133e 4c63440150 movsxd r8,dword ptr [rcx+rax+50h] ds:00000000`00007750=????????
Resetting default scope
EXCEPTION_RECORD: 000000e0c15fdf70 -- (.exr 0xe0c15fdf70)
ExceptionAddress: 00007ffea66c133e (opennurbs!ON_Brep::IsValid+0x0000000000000d0e)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 0000000000007750
Attempt to read from address 0000000000007750
PROCESS_NAME: Rhino.exe
ERROR_CODE: (NTSTATUS) 0xe0434f4d - <Unable to get error code text>
EXCEPTION_CODE_STR: 80004003
READ_ADDRESS: 0000000000007750
FAULTING_THREAD: ffffffff
STACK_TEXT:
000000e0`c15fe630 00000000`00000001 RhinoCommon!UnsafeNativeMethods.ON_Object_IsValid+0x2
000000e0`c15fe6e0 00007fff`51c2f5c8 HelloGrasshopper!HelloGrasshopper.TestComponent.ComputeResult+0x588
000000e0`c15fe980 00007fff`aa34a6e9 mscorlib_ni!System.Threading.Tasks.Task`1[[System.Boolean, mscorlib]].InnerInvoke+0x29
000000e0`c15fe9b0 00007fff`a9a07a48 mscorlib_ni!System.Threading.Tasks.Task.Execute+0x48
000000e0`c15fe9f0 00007fff`a99de9a9 mscorlib_ni!System.Threading.ExecutionContext.RunInternal+0x109
000000e0`c15feac0 00007fff`a99de896 mscorlib_ni!System.Threading.ExecutionContext.Run+0x16
000000e0`c15feaf0 00007fff`a9a08ac2 mscorlib_ni!System.Threading.Tasks.Task.ExecuteWithThreadLocal+0x232
000000e0`c15feba0 00007fff`a9a07b92 mscorlib_ni!System.Threading.Tasks.Task.ExecuteEntry+0xa2
000000e0`c15febe0 00007fff`a9a19c17 mscorlib_ni!System.Threading.ThreadPoolWorkQueue.Dispatch+0x157
STACK_COMMAND: !C:\ProgramData\Dbg\sym\SOS_AMD64_AMD64_4.8.9075.00.dll\62CCE36B9a4000\SOS_AMD64_AMD64_4.8.9075.00.dll.pe 0x278e90ddc28 ; ** Pseudo Context ** ManagedPseudo ** Value: ffffffff ** ; kb
SYMBOL_NAME: RhinoCommon!UnsafeNativeMethods.ON_Object_IsValid+2
MODULE_NAME: RhinoCommon
IMAGE_NAME: RhinoCommon.dll
FAILURE_BUCKET_ID: CLR_EXCEPTION_System.AccessViolationException_80004003_RhinoCommon.dll!UnsafeNativeMethods.ON_Object_IsValid
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
IMAGE_VERSION: 7.23.22282.13001
FAILURE_ID_HASH: {916043c9-e986-3c9b-fa86-4b33e114c865}
Followup: MachineOwner
