I am working on building an event handler that mainly writes User Text to objects given certain conditions. I have discovered that some of the events return a Rhino object, while others do not.
From the events that I’ve tested, it’s only with AddRhinoObject, DeleteRhinoObject, ReplaceRhinoObject that return an object. As a workaround, I’m using SelectObjects and then working with rs.SelectedObjects() to loop through selected objects and modifying user text, layers, etc.
Is there a better way to do this?
I’m working with an adapted version of the script from @dale from here:
And am finding that it’s also not running in V8. Have there been changes to the way that Events are handled in V8?
Thanks,
Dan
