Accessing guid (sliderguid)
Can I access the guid (sliderguid) of a component connected to the input of ghpython component?
Short answer: Yes.
Try to translate this to Python:
    // Checking the first Input param (at index = 0)
    var param = Component.Params.Input[0];
    if (param.Sources.Count < 1)
        return; // No source was connected to inport
    // get the actual source component
    var gh = Component.OnPingDocument();
    var id = param.Sources[0].Attributes.Parent.InstanceGuid; // <-- you want this
    var source_component = gh.FindComponent(id);
    if (source_component == null)
        return; // Failed to access the source component
    // From here you're good to go
// Rolf
Thanks Rolf,
I’ll try.
Ops, that code seems to work only when having a ScriptComponent as the source (not a slider).
This should work better for a Slider:
    A = param.Sources[0].InstanceGuid; // Output the Guid
// Rolf
Thanks it worked with csharp component, I’ll try to translate it.
Is there a similar method to access guid of down stream components?
likewise I tried Component.Params.Output[0].Sources[0]
but Sources is empty list even if I have stuff connected to it…
You cannot connect a source to an output parameter. Parameters have Sources (connected to the left hand side) and Recipients (connected to the right hand side).
@Will_Wang
I saw a script provided by @piac where he uses Reflection inside python to get inputs downstream.
He was basically checking what type of object was connected to the component this.component was connected to :smiley:
