I’m looking for something similar as the component directory contents from human plugin. Basically what it does, is allow you to scroll through the files you have in the folder. BUT what this component didn’t do is showing the folders inside this main folder and let you select them…
the thing is it gives you everthing that are in the sub folders. When I have alot of files in the subfolders it crashes. Anything to only see the content of the inputted folder ?
You can see I left the other two options commented.
a = Directory.GetDirectories(x) #this will list only the folders in the path
b = Directory.GetFiles(x) # this will give you the files inside the path
c = Directory.GetFiles(x, "*",SearchOption.AllDirectories) # this will give you all files and folders including subfolders. Everything inside the path. You can change "*" to "*.txt" and it will list all directories/subdirectories and files with extension txt.
If you zoom in the component you’ll see little + signs you can add outputs “b” and “c” there.
a = [] # define a as empty list
dir = Directory.GetDirectories(x) #define variable dir containing list of all directories
files = Directory.GetFiles(x) # define variable files containing list of all files
for d in dir:
a.append(d) # adding the contents of dir into a (the folders)
for f in files:
a.append(f) # adding the contents of files into a (the files)
Though at the end I don’t know how to sort list a. You’ll just get a list of first all folders and then all files. (that is files in the path, without subfolders)
I did not test it. I’ll test it when I find some more time.
