5 axis milling automation
We are interested in investigating the automation of 5 axis CAM for machining panel type geometry (auto headliners, dashboard panels, and some deep space applications).
While the geometry changes with each project the “process” is very redundant.
What CAM software do you currently use? Or are you looking to create something “from scratch”?
interesting, below is a 3-axis simulation I’ve done in Grasshopper
Currently we are using CREO for both CAD and CAM.
Interesting. If you changed the geometry would you need to create a new process or would the process automatically update to the new geometry?
Since I’m using Grasshopper to generate a toolpath, the geometry can be changed and the toolpath is updated accordingly
Martin: Can we talk on the phone? my cell is 419-575-4395
Martin: I just saw that you are in Switzerland of course different time zones. Perhaps it will be easier initially to communicate here.
Please send me a personal message
my email is: tclark@clarkfixtures.com. That may be easier.
:exploding_head:
Is that stock removal scallop geometry a mesh? or nurbs, subD…?
The blue thing? It’s a capped pipe… nurbs…
No, I surmise the blue thing is the tool. I"m referring to the tan/cream color board thing – the ‘stock’ itself per say. Is that part nurbs too?
Oh that’s a skateboard. It starts as a rectangular mesh or SubD. Before trimming the raw ‘pressed’ plywood, the SubD is converted to Nurbs and then it is split with the board shape.
