by Trey DeWolf
I like that jig at 11:11
Extraordinary work, from a student, no less.
What surprised me were these words on his âAbout Meâ page: âHaving severe dyslexiaâ
Iâll have to update my poor understanding of dyslexia!
Dyslexia shmishlexia - his brain just works differently. Lucky him.
Iâve 3d printed jigs before to hold pieces of wood in the right orientation to then CNC machine a face. I did it when I made a handrail for a spiral staircase. With a 3-axis CNC you can take some of the complexity out of the jig and obviously with more axes you can remove the need for a jig completely.
I often use 3d printed jigs for drilling dowels in the right place and orientation too. I use drill collars set into the 3d printed jig to align the drill.
This case study is really impressive though. I sympathised with the assembly where he experienced a cumulative error⌠When I glued up my handrail I started at the top and worked down the stairs getting more and more panicky that nothing would line up by the time I got to the bottom. It worked OK, but the top piece moved slightly and I have a small gap now at the top which I notice almost every time I go up the stairs ![]()
That is stunning, fantasticly complex woodworking - Congratulations Trey
super impressing!!! ![]()
Dyslexia, when writing, is a more or less âdisconnectâ between what you intend to write and what you actually write." A bit like a glitching cable between the keyboard and the computer. Except for the brain sees your intented text, not the actual text. After an hour or two (when the brain no longer âexpectsâ what the text should read) youâre more likely to spot your own spelling mistakes and missing words etc.
Gets worse when tired or over strained (lack of sleep, etc) due to the way our brains prioritize when the brain gets tired.
The verbal system is the first âperipheral systemâ that shuts down when the brain is overstrained. So itâs not a weakness intellectually (although exactly that is what it looks like to some).
Common among software developers, and reading their posts with a lot of spelling errors indicates that they missed a nights sleepâŚ
My own experience.
There are worse dyskexia conditions than described above.
The level described above is on a level which most people have experienced after drinking alcohol - the verbal system is the first to suffer/shut down⌠(speech, sluddering etc)
//Rolf
