I am not sure I understand use of [System.Runtime.InteropServices.Guid(“00000000-0000-0000-0000-000000000000
”)] attrubute. Should i use it before every command?
Would appreciate if someone could explain when and why should one use this attribute. ( I am not planning to interface with COM. )
Here is typical structure i have used for multiple commands.
[System.Runtime.InteropServices.Guid("259CB426-2F44-4B03-A818-DAA7413C432D")]
public class MyProject_Command1 : Command
public MyProject_Command1()
Instance = this;
public static MyProject_Command1 Instance
get;
private set;
public override string EnglishName
get { return "MyProject_Command1"; }
return Result.Success;
[System.Runtime.InteropServices.Guid("dd6c90d3-5fc7-48bb-9776-1e34886cc954")]
public class MyProject_Command2 : Command
public MyProject_Command2()
Instance = this;
public static MyProject_Command2 Instance
get;
private set;
get { return "MyProject_Command2"; }
