I find that I often need a temporary tolerance and messing with the absolute tolerance is risky as we can forget to set it right again.
I envision a button next to “Record History” that can be clicked and like “Record History” stays active until the next command is finished.
This would be great for tools like Make2D, “flow along surface”, twist, taper and other tools used when sketching.
We often sketch in the same file that we construct in, so lowering the tolerance from 0.001 to 0.1 in the settings can be risky if we undo a lot, and forget to check the tolerance before further modelling.
Do you have any specific examples of this requirment? I feel I’m missing an important point here, where I’ve been modelling something it’s always set to 0.001mm as standard.
What benefits are there for changing the tolerance? I understand that there are situations where you don’t need to be very accurate, say, placing a door frame within a room doesn’t need fractions of a mm accuracy but what benefit is it to work with 0.1 rather than .001?
I’m hoping it’s something daft I’ve missed and it’s staring me right in the face…
Make2D for example works much quicker with a lower tolerance setting.
I think it’s a good suggestion as it would help make users more aware of tolerance, and would also be a good visual aid to remember to adjust it when needed.
Yes, but I imagine that would require more programming and was the main reason why it had not been implemented on more tools. So therefore I figured a temporary toggle could solve most needs.
All the UDT tools (Bend, flow, twist, taper etc) and also cage edit are tools that benefit from lowering the tolerance WHEN SKETCHING. I never use the UDT tools for prodcution since it adds too much data (isocurves) to stay within tolerance.
Projecting curves can also be with a low tolerance, as these might not need to be withing production tolerance. (The main benefit is keeping pointcounts low for further modelling)
When modelling for production it is important to keep the tolerance tight.
fwiw, when i first started using rhino, tolerances were one of the most confusing things to understand… i get it that a temp button is useful but my point is more about it being an advanced user feature… not sure if it should be so prominent as to place it in the main GUI… unless it was something you turned on in the preferences (or similar)
Yes !
A way to handle tolerances would be very helpful.
Just being able to see the tolerance value on the screen (permanently) would help not to forget to reset its value.
I often do that …
Talking about V6, a thing that I think Rhino is missing is a way to have useful values constantly shown to the user.
I’m thinking about some kind of ‘toolbar’ … maybe a ‘valuebar’ or ‘infobar’ where the ‘button’ would be like message boxes with user defined expressions, say Tolerance, GridStep, etc …
That way we could easily check values that we like/need to know … but may have forgotten about
Thanks
FWIW, for this particular issue, I think that Pascal’s suggustion is the way to go - i.e. add a modifier to the command. Something that is permanently in your face is likely to go unnoticed when it matters most and you’ll end up having to go back and redo things anyway.
There are a few commands already that have tolerance settings specific to the command.
The one I can think of now is Convert.
That, I think, is what Pascal is suggesting.
