Updating Contours using History
I’ve just tried using the Contour command on a surface with History activated. When I modify the surface, the contours fail to update.
This should be possible, right?
Hi Neil - Contour is not aware of History yet. Use Project with a set of parallel lines (with History) to get this effect. The input lines can remain on an Off layer.
Ok thanks. I’m actually trying to use it in a much more complex terrain model. So, I don’t think Project will work in quite the way I need it to. I guess I’ll just update manually until it gets the History function.
