Correct - one shots override the persistents for one pick.
Very good. Thanks. btw, Iād found a setting that controlled the zoom ratio of the mouse wheel. I can no longer find it. Where is that? Iām presently set to .95 and Iād like to slow it down further.
Maybe you can describe exactly how you move things āorthogonallyā. That might be one cause of the problem.
āMitch
Rhinoceros > Preferences > View: Zoom Scale Factor
Do you know if youāre actually snapping the end of the curve youāre moving to the place you want on the perpendicular line? --Mitch
Of course. Senior moment it is. Thanks.
Yes. After dragging a copy along the axis, I use the move tool to grab it at the end and place it on the spot it needs to be. In this case at the intersection, end, quaddrant.
Once you have started the move command and started dragging the object, if you tap the āTabā keyboard button then the drag direction is locked. Used with ortho on, in this case, the end-pt of the curve being moved will end up aligned with the destination pt as opposed to on it, so any slight mis-alignment of the destination wonāt affect the ortho movement.
I forgot about the tab key. Iāll use that with the copy command which is just grand. Iām running the mac version of R so Iām not sure if the file is .rui, is that a windows thing?
Someone else can tell us how the Mac version works, but in the Windows version, access to the toolbar āsave asā is from the properties dialog and the file you create resides in the McNeel/Rhinoceros/5.0/UI folder shown below.
I recorded a short screencast that might be of interest to you. Iām not sure why you want to build your geometry by projecting lines. Thinking that this might be an artifact of your previous experience with CAD Iām suggesting another way for you to look at the object developmentā¦not judging though.
Chris
Per emilioās comment above I would double check your tolerance settings.
This sounds like an issue you might have if you are trying to draw something in mm and your tolerance settings are set to large object feet.
http://wiki.mcneel.com/rhino/faqtolerances
As a newer user I would take the time to read the users guide. It will help you better understand the architecture of the program.
This is a very worrying thing to read as I need to move an object perfect up with the Gumball I set it to Align to World. If this is not true I sure hope i have not screwed up any buildings!!
