can anybody provide a script that shows a mesh´s vertex numbers in the viewport (and ideally outputs them to dots)
thanks in advance for any help
roberto
Hi Roberto,
this is the simplest version i got which only shows vertices as grouped annotations in python. If you need vbscript let me know:
def NumerizeMeshVertices():
m_id = rs.GetObject("Select a mesh", 32, True, False)
if not m_id: return
mesh = rs.coercemesh(m_id)
dots = []
rs.EnableRedraw(False)
for i, v in enumerate(mesh.Vertices):
dots.append(rs.AddTextDot(i, v))
rs.AddObjectsToGroup(dots, rs.AddGroup())
rs.EnableRedraw(True)
if __name__=="__main__":
Or as script file: NumerizeMeshVerts.py (441 Bytes)
You can use this to load it:
! _-RunPythonScript "C:\YourPathToTheScript\NumerizeMeshVerts.py"
c.
hi clement,
thanks a lot !
(wie gewohnt vom feinsten)
cheers
roberto
