Pass an array to Rhino.Command?
In RhinoScript I’m trying to make something like a rotate around curve, and what I want to do is to pass an array of objects to rotate
Rhino.Command "Rotate3d SelID " & arrObjects
I could use Rhino.GetAngle and then Rhino.RotateObjects instead, but was hoping to to use Rhino.Command “Rotate3d” so the user could get a preview of the geometry rotating about. Any ideas?
Thanks,
Sam
do the following:
rs.UnselectAllObjects()
rs.SelectObjects( *your array of IDs )
rs.Command("_Rotate")
Optionally, include a rotation point in your rotate command. “_Rotate 0,0,0” (check the syntax yourself, I’m not sure thats exactly correct)
Oh goodness, that was simple :blush: Thank you,
Sam
