How can i close the bold lines outside the bottle? I can’t make a boolian union.
thanks ,
Ronald
thanks ,
Ronald
There are no files attached to your post - making it rather hard to offer any help.
Hmmm- if I understand what you want, I would ExtractIsocurve from the outer surface where you want the rings - this will get you clean circles, which you can then Pipe and Union to the object. You could also Revolve a small circle or make a thin Torus to make the rings.
that works fine Pascal but the rings are not in a straigt line. They go a little bit up and down…the ring must follow the lines but it doesn’t work with array along curve.
I found it!!! Rail revolve!!!
