GetString with numeric values in Option List issues
All,
I am having issues understanding how to present to the user numeric values when my input list for GetString.AddOptionList contains numeric values. I have checked the types of all objects in my list and they are in fact strings, however any numeric values will not show up. If I have a mixed list with (1,2.0,Three,Four) the user is only presented with Three and Four as options.
Any insight would be greatly appreciated.
Joel
Any option name may not start with a numeric character, but it can contain numerical characters (“Option1”, “Option2”).
If you want to get a numeric value from a user it is best practice to use RhinoGet.GetNumber or RhinoGet.GetInteger. If part of a larger set of options, use GetOption.AddOptionDouble or GetOption.AddOptionInteger.
Examples at
SDK docs at
http://4.rhino3d.com/5/rhinocommon/html/M_Rhino_Input_Custom_GetBaseClass_AddOptionDouble_2.htm
http://4.rhino3d.com/5/rhinocommon/html/M_Rhino_Input_Custom_GetBaseClass_AddOptionInteger_2.htm
^ Yep. It’s pretty annoying that I have to use some symbol infront of the number to have that selection option and then cut it out of the string afterwards…
Hi @stevebaer, @dale
Add Command Line Options shows an example with a single OptionList.
Is it possible to use more than one OptionList (say three), and can we get an example of it?
Thank you in advance!
You should be able to. Did you try and run into problems?
Hi @stevebaer,
I did. I defined the second OptionList, added it to the GetPoint object, and then copied the:
if gp.OptionIndex()==opList2:
  listIndex2 = gp.Option().CurrentListOptionIndex
continue
But still I never get the chosen “listIndex2”. Only it initially defined value.
Is it possible to provide an example with at least two OptionList please?
Here’s a tweaked version of the sample
import Rhino
import scriptcontext
def CommandLineOptions():
    # For this example we will use a GetPoint class, but all of the custom
    # "Get" classes support command line options.
    gp = Rhino.Input.Custom.GetPoint()
    gp.SetCommandPrompt("GetPoint with options")
    # set up the options
    intOption = Rhino.Input.Custom.OptionInteger(1, 1, 99)
    dblOption = Rhino.Input.Custom.OptionDouble(2.2, 0, 99.9)
    boolOption = Rhino.Input.Custom.OptionToggle(True, "Off", "On")
    listValues = "Item0", "Item1", "Item2", "Item3", "Item4"
    list2Values = "Bear", "Duck", "Zebra"
    gp.AddOptionInteger("Integer", intOption)
    gp.AddOptionDouble("Double", dblOption)
    gp.AddOptionToggle("Boolean", boolOption)
    listIndex = 3
    opList = gp.AddOptionList("List", listValues, listIndex)
    list2Index = 1
    opList2 = gp.AddOptionList("Animal", list2Values, list2Index)
    while True:
        # perform the get operation. This will prompt the user to
        # input a point, but also allow for command line options
        # defined above
        get_rc = gp.Get()
        if gp.CommandResult()!=Rhino.Commands.Result.Success:
            return gp.CommandResult()
        if get_rc==Rhino.Input.GetResult.Point:
            point = gp.Point()
            scriptcontext.doc.Objects.AddPoint(point)
            scriptcontext.doc.Views.Redraw()
            print "Command line option values are"
            print " Integer =", intOption.CurrentValue
            print " Double =", dblOption.CurrentValue
            print " Boolean =", boolOption.CurrentValue
            print " List =", listValues[listIndex]
            print " Animal =", list2Values[list2Index]
        elif get_rc==Rhino.Input.GetResult.Option:
            if gp.OptionIndex()==opList:
              listIndex = gp.Option().CurrentListOptionIndex
              list2Index = gp.Option().CurrentListOptionIndex
            continue
        break
    return Rhino.Commands.Result.Success
if __name__ == "__main__":
Hi @djordje,
Here is another example of a Get that has multiple options lists.
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinocommon/cs/SampleCsCommands/SampleCsOptionsList.cs
– Dale
