To create a pageview I do:
pageview = doc.Views.AddPageView(“MyPage”, _pageSize.Width, _pageSize.Height);
How I can get the page view Width and Height again from the pageview object?
Thanks,
Alex.
Thanks,
Alex.
Funny, I was looking into exactly teh same thing yesterday!
I think that this is not (yet) in RhinoCommon. In C++ you can call void GetPaperSize(ON::unit_system units, double& width, double& height) const;
on a PageView. We could ask @stevebaer to add this to RhinoCommon
But: if you create the view yourself, you could save the size for later use maybe? This is what I ended up doing.
Hi Menno,
Thanks for your answer. The problem is I need to save in the doc this info to use it in the future.
Regards,
Alex
Maybe you can use SetDocumentUserText?
Or use PlugIn.WriteDocument
and PlugIn.ReadDocument
to write/read plug-in data.
Be sure to implement PlugIn.ShouldCallWriteDocument
too!
RhinoPageView.PageWidth and RhinoPageView.PageHeight properties are available in RhinoCommon in SR10
