Hello all,
Is there a way to draw Ellipsoids in either rhinoscriptsyntax or rhinocommon?
i am particularly interested in ellipsoids from foci.
thanks,
tomás
Hello all,
thanks,
tomás
RhinoCommon has an Ellipse type, which exposes a ToNurbsCurve method.
There is no constructor that takes focal points though, but that is a fairly trivial geometric exercise.
You might use the regular FromFocii option and script the rhino command in rhinoscriptsyntax:
import Rhino
def EllipseFromFocii():
pt0 = Rhino.Geometry.Point3d(-10.0, 0.0, 0.0)
pt1 = Rhino.Geometry.Point3d(10.0, 0.0, 0.0)
pt2 = Rhino.Geometry.Point3d(0.0, 10.0, 0.0)
cmd = "_Ellipse _FromFoci " + str(pt0) + " " + str(pt1) + " " + str(pt2)
rs.Command(cmd, echo=False)
if __name__=="__main__":
EllipseFromFocii()
@stevebaer i think the echo=False
does not work properly here, i still get the eccentricity value listed after the command completed.
c.
FWIW, an ellipsoid is a parametric surface and an ellipse is a curve. As far as I know the ellipsoid shape is basically two perpendicular ellipses sharing a common axis (right?).
You would probably be fastest to create a sphere and use a non-uniform scaling transform to get to the ellipsoid shape. What remains is to calculate the length of the 3 axes in the example below from the foci points.
NurbsSurface ns = NurbsSurface.CreateFromSphere(new Sphere(Point3d.Origin, 1));
double xAxis = 2, yAxis = 3, zAxis = 4;
Transform scale = Transform.Scale(Plane.WorldXY, xAxis, yAxis, zAxis);
ns.Transform(scale);
LOL, yes menno thanks, i was reading too fast and an ellipse was mentioned above my first post Below is the correction for an ellipsoid from focii:
import Rhino
def EllipsoidFromFocii():
cmd = "_Ellipsoid _FromFoci " + str(pt0) + " " + str(pt1) + " " + str(pt2)
c.
Thanks david, clement and menno.
Yes i was referring to the ellipsoid and your answers helped. I in fact hadn’t considered using rs.Command. The only thing missing now is the resulting ellipsoids GUID so that i can continue working with it?
How do i get the GUID?
rs.Coomand returns a boolean.
thanks again.
tomas
The boolean is the command result. Here is an extended version which prints the id on success:
import Rhino
blnResult = rs.Command(cmd, echo=False)
if blnResult == True:
ids = rs.LastCreatedObjects()
print ids[0]
else:
print "Error creating ellipsoid"
You may too look at rs.LastCommandResult()
for extended options why a scripted command failed.
c.
Thanks very much clement. That works.
tomás
