Clipping Planes always active on Worksession
Hi Guys, I cannot turn off the clipping planes of my colleague when importing their files on worksession. Does anyone else have this problem?
You may attach a file as example. It will be easier to check the problem.
Hey Arthur,
I see something different here. I made a cube and inserted a clipping plane to partially clip the cube. I then saved the file and closed it. Then I made another file with another cube and clipped that, and saved it. Then I attached the first file to the second as a worksession.
I see the clipping plane object in the attached file, but it doesn’t clip anything at all… The clipping plane in the active principal file clips both objects in its own file plus those in the the attached file…
I don’t know what the behavior is supposed to be here.
–Mitch
But probably not what you’re seeing, eh? :smile:
