Hi all,
Reporting what seems like a bug in the UserText functionality.
In the Rhino help file the following is stated in regards to user text:
AttachTo
Object
Attaches text information to the object geometry.
If the information is closely associated with the geometry, attach it to the geometry. For example, a circle’s radius should be attached to the geometry because the information will be invalid if the circle is control-point edited and changed into a NURBS curve.
I would expect the user text attached to geometry to be cleared when the geometry changes. Editing the control points of a circle with a user text string attached to geometry does not clear the user text.
If you split the circle in two with a line, both resulting curves retain geometry user text.
Only when trimming the circle with a line is the geometry user text cleared.
Is this the expected behaviour and just badly explained in the help file, or is it actually a bug?
GM
