Hi friends
I selected several objects on the screen, however need to create a single bounding box around all objects, so I can move them to another point. It would be possible to post an example in C # that make this function.
Thanks
Hi friends
Thanks
Calculate the bounding box of each object and then union the bounding boxes (together) using Rhino.Geometry.BoundingBox.Union
. Does this help?
Below is the code what Iām trying to do, the problem is that central point is not generated from the bounding box that encompasses all objects.
var go = new Rhino.Input.Custom.GetObject();
go.SetCommandPrompt("Select objects");
go.EnablePreSelect(true, true);
go.EnablePostSelect(true);
go.GetMultiple(0, 0);
if (go.CommandResult() != Result.Success)
return go.CommandResult();
Point3d pt = new Point3d(0, 0, 0);
var bBox = new BoundingBox();
var selected_objects = go.Objects().ToList();
foreach (var obj in go.Objects())
bBox = obj.Geometry().GetBoundingBox(true);
bBox.Union(pt);
doc.Objects.AddPoint(bBox.Center);
doc.Views.Redraw();
return Result.Success;
What you want to do is this
BoundingBox bBox = BoundingBox.Unset;
BoundingBox bbObj = obj.Geometry().GetBoundingBox(true);
bBox.Union(bbObj); // union the object bounding box with the overall bounding box
doc.Objects.AddBrep(bBox.ToBrep()); // see the box
doc.Objects.AddPoint(bBox.Center); // see the center
doc.Views.Redraw();
100% Functional.
Thank you all
