I am still a new user and still trying to learn my way around Rhino For Mac, so not sure if my questions are a result of not knowing the software or the limitations of the Beta version.
Unfortunately the command: -viewcapturetofile is not available, so the only other way I can think of to capture a high resolution version of a current viewport, which happens to be shaded is to:
zoom in -> capture to clipboard -> paste in photoshop then repeat the process. Then when I have enough sections, I arrange and combine into a whole… which is quite arduous.
–To speed up the process I have tried to use the “zoom window / target tool” then capture to clipboard etc. However, when I try to use the zoom window tool I get the following message:
This command works on OS X Mavericks only when OpenGL anti-aliasing is set to None. Change anti-aliasing to None and restart Rhino to enable this command.
My question:
Is not being able to use the “zoom window / target tool” while having anti-aliasing ON because Rhino For Mac is in beta, or is this not available on the windows version either?
Thanks for any help AND for reading my long winded question
Dom
