Zoom window and zoom target on mac WIP8
zoom window and zoom target are not zooming right in on the mac version of WIP
also there is odd behaviour when trying to open or save a file if rhino and GH are sharing a desktop…it is neccessary to swipe up to the desktops before the file manager window will appear.
zoom problem is only in perspective
hi @giusseppe I cannot repeat the issues you are describing here. Is this still an issue for you in the latest WIP? pls run _SystemInfo and post back the results.
Hi, it is only a problem in perspective view…the zoom window and zoom target only make a small jump instead of zooming right in as they do on other views.
rhino.txt (5.0 KB)
they have not been working for a while…and I have the latest WIP
Just to be clear, this is only a problem in the WIP…it has always worked in other Rhino versions.
Can you share a video of what you are seeing? Based on your description and systeminfo, I don’t have any clues why this would happen.
Can you also confirm something for me please…if I want to see packed face colours on a subd object before using ToNurbs is it usual that I can only see the colours in Ghosted,Xray or Arctic view and not in Shaded ?
did you ever find out why the zoom target is not working on the mac?
Hi @giusseppe sorry I missed your reply earlier. Does this happen also in a fresh new file with just a box?
Edit: it looks in the video that’s a yes. I see other odd things happening with the Radeon Pro 560x
yes to anything…even a single point…I guess you are saying that these oddities cannot be solved for my mac…I can live with that😊
I took another look at this and noticed you are using linked viewports. I can repeat your issue when that is active.
RH-77333 Linked viewports breaks Zoom Target
(the facepack color issue I cannot repeat here though)
happens to me even if I only have rhino window open without GH
