When using the '_Zoom tool, unlike the previous version, if you enlarge the desired part of the object in version 7, the viewport rotation axis is set in the empty space behind the object. So, if you rotate the screen, the magnified object goes very far in the viewport, so to see another part of the object, you have to drag it for a long time with shift + left click again, which is very inconvenient.
Do I need to set a separate setting to get the rotation axis to fit snugly like the previous version?
I have attached a video recording the difference between using [’_Zoom] in version 7 and previous versions.
