Zoom to object with no gaps around it (Just like AutoCAD does)
Hi everyone!
Just trying to zoom-to-object with no gaps, just like AutoCAD does. Rhino has zoom to object but it leaves a gap around the object.
Any help will he highly appreciated!
Hi @Fernando_González-Ca ,
#farouk.serragedine@gmail.com for custom made solutions - Rhinoceros Plugins
import Rhino
def ZoomToTightBoundingBox():
    object_ids = rs.SelectedObjects()
    if not object_ids:
        object_ids = rs.GetObjects("Select objects to zoom tightly", preselect=True)
        if not object_ids: return
    # Get the bounding box of the selected objects
    bounding_box = rs.BoundingBox(object_ids)
    if not bounding_box: return
    box = Rhino.Geometry.BoundingBox(bounding_box)
    # Get the active view
    view = rs.CurrentView()
    if not view: return
    rhino_view = Rhino.RhinoDoc.ActiveDoc.Views.Find(view, False)
    # Calculate the tight zoom factor
    rhino_view.ActiveViewport.ZoomBoundingBox(box)
    rhino_view.Redraw()
if __name__ == "__main__":
Select an object and then run the script.
It will work precisely as autocad does and leave no gaps in the zoom as requested.
Hope this helps,
Farouk
Thanks for such a quick reply! That sounds excactly like what I need. However I get this error when loading the script:
It’s a python script, not a rhinoscript.
Anyway I compiled an Rhi for you I guess It’ll be easier.
Just execute the rhi, then type in the rhino console “zoomnogap”
zoomnogap.rhi (4.1 KB)
Farouk
Hi Fernando -
You can set the advanced option Rhino.Options.View.ZoomExtentsParallelViewBorder to 1 to achieve this.
Thanks a lot everyone!! amazing to get such quick responses!! Wim’s solution worked wonders!!
“You can set the advanced option Rhino.Options.View.ZoomExtentsParallelViewBorder to 1 to achieve this.”
Fernando
