Zoom - Rhino WIP
zoom window does not work on mac with m1 max processor, on rhino wip
Hi -
Could you please explicitly state the steps that you are taking?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR0 2022-1-11 (Rhino WIP, 8.0.22011.12316, Git hash:master @ e61fc78d7ed6bc889c1402fc0b8bf4337d761825)
License type: Commercial, build 2022-01-11
License details: Cloud Zoo
Expires on: 2022-02-25
Apple macOS Version 12.1 (Build 21C52) (Physical RAM: 64Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,2
Language: en-TR (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 43690 MB
Graphics: Apple G13X
Displays: Unknown (255dpi 2x)
Graphics processors
Apple G13X
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/agah/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/FJ_FreeJewelsToolbar.rhp “FJ_FreeJewelsToolbar” 1.0.0.0
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/Connections.rhp “Connections” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConnectionsUI.rhp “ConnectionsUI” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22011.12316
testmetal doesn’t work when open, works when i close it
Hi -
Correct me if I’m wrong…
The issue you are reporting in this thread is that, when you enable TestMetal, when you run the Zoom command and drag across a viewport, a window should be drawn in the viewport and that is not the case. When disabling TestMetal, the window is drawn as expected.
This issue is on the list as RH-67000.
yes that is exactly the problem, thank you
