For mouse scroll zoom in/out, is there way to make the zooming in lesser steps? Zoom nudge sort of?
Panning is ok, but for zooming I haven’t found setting to change on the fly.
For most cases, default setting is ok for zooming.
I’d just like to be able to zoom slightly when captureing viewport to file,
or when snapping to a point, but normal zoom goes in too far in and passes the point.
Are you zooming with mouse wheel or Ctrl+RMB ? Ctrl+RMB seems to be more precise…
Thanks @Jarek. Totally forgot about using RMB… Just so used to scroll wheel for zooming.
Setting to solved.
Great. Also, if you want the camera to stay in place, Ctrl+Shift+RMB zooms using the lens, not moving the camera. May be handy in some situations.
One other tidbit, if you use Alt + RMB (or Alt + Middle Mouse Wheel), it will move the camera and the target, so you don’t go smashing into the target and the zoom slows down.
Sam
