Rhino won’t center a perspective view when zooming extents. All other views are centered which would indicate that there are no other objects in the total geometry that could cause this. If I switch the perspective view to parallel via the viewport properties dialog the view centers correctly when zooming extents.
The camera lens it at 50mm
What could cause this behaviour ?
Yeah… if you turn on the camera (F6) you’ll see why this is… I think that explains it anyway. Not sure what to do about it off hand though.
I see … well that’s definitely some to be fixed. It doesn’t seem to be a problem in Max or C4d or even Autocad …
