Zoom Extends All viewports not working properly
As the title says, I have problems with Zoom Extends All Viewports.
The command does not work with Layouts. Is that normal?
Hi Martin, ZEA does not work in layout details, if that is what you mean. it works in a layout as a whole - but it not, as far as I can see, any different from ZE in that context since there is only one viewport.
This python may help -
import Rhino
import scriptcontext as sc
def ZELayouts():
    views = sc.doc.Views.GetPageViews()
    for view in views:
        sc.doc.Views.ActiveView = view
        view.ActiveViewport.ZoomExtents()
        view.Redraw()
ZELayouts()
So when I want a dozen of layouts all zoomed as large as possible, I have to click the command again and again for every layout?
Yep.
My plugin has a script for that, if that helps. The command is DetailsTools:
Thanks I might try that.
I am having the same issue with the current version of Rhino 7
I updated Rhino7 ro SR35 about two weeks ago and since then the ZEA stopperd working for all the layouts apart from the oine I had up on the screen.
Up until Rhino 7 I found ZEA worked ok on ALL layouts so I am silgthly baffled by the response to Martin.
Does the ZEA button operate a python script or is this a “built in” command that has been changed in Rhino 7
Logikman
