Zoom commands move viewpoint
Build 504. Zoom commands Zoom Extents, Zoom Extents All and Zoom Selected seem to move the camera viewpoint in perspective view. When I am looking at an object from above, these zoom command cause the camera to rotate such that it is at equal height to the object. I believe this did not happen in older versions. Is this intentional?
Max.
All is back to normal. I remembered that I had been playing with the “Change View Projection” command, so I tried that again, and bingo! I cannot reproduce the problem anymore. It did have another effect in that objects got visually distorted when you moved the camera viewpoint to anything else but “eye-level”.
Max.
