zoo crashes on Windows 2012 Server while adding a new license
Application Error ID 1000
Faulting application name: ZooAdmin.Wpf.exe, version: 6.10.18275.5111, time stamp: 0x5bb37d90
Faulting module name: KERNELBASE.dll, version: 6.3.9600.19425, time stamp: 0x5d26ae6e
Exception code: 0xe0434352
Fault offset: 0x00034e28
Faulting process id: 0x1250
Faulting application start time: 0x01d5af3e7f9f07da
Faulting application path: C:\Program Files (x86)\Zoo 6\ZooAdmin.Wpf.exe
Faulting module path: C:\windows\SYSTEM32\KERNELBASE.dll
Report Id: e4d6c375-1b31-11ea-80f0-0050569a691a
Faulting package full name:
Faulting package-relative application ID
Error .NET Runtime ID 1026
Application: ZooAdmin.Wpf.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
Stack:
at System.Windows.Window.ShowDialog()
at Eto.Wpf.Forms.DialogHandler.ShowModal()
at Eto.Forms.Dialog.ShowModal()
at Eto.Forms.Dialog.ShowModal(Eto.Forms.Control)
at ZooAdmin.ViewModels.MainFormViewModel.OnAddCommand()
at ZooAdmin.MainForm.b__34_3(System.Object, System.EventArgs)
at Eto.Forms.Command.OnExecuted(System.EventArgs)
at Eto.Forms.Command.System.Windows.Input.ICommand.Execute(System.Object)
at Eto.PropertyStore+CommandWrapper.Command_Execute(System.Object, System.EventArgs)
at Eto.Forms.ToolItem.OnClick(System.EventArgs)
at Eto.Wpf.Forms.ToolBar.ButtonToolItemHandler.<.ctor>b__3_0(System.Object, System.Windows.RoutedEventArgs)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean)
at System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs)
at System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(System.Windows.Input.MouseButtonEventArgs)
at System.Windows.UIElement.OnMouseLeftButtonUpThunk(System.Object, System.Windows.Input.MouseButtonEventArgs)
at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(System.Delegate, System.Object)
at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object)
at System.Windows.UIElement.ReRaiseEventAs(System.Windows.DependencyObject, System.Windows.RoutedEventArgs, System.Windows.RoutedEvent)
at System.Windows.UIElement.OnMouseUpThunk(System.Object, System.Windows.Input.MouseButtonEventArgs)
at System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs)
at System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr, System.Windows.Input.InputMode, Int32, System.Windows.Input.RawMouseActions, Int32, Int32, Int32)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr, MS.Internal.Interop.WindowMessage, IntPtr, IntPtr, Boolean ByRef)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at Eto.Wpf.Forms.ApplicationHandler.Run()
at Eto.Forms.Application.Run(Eto.Forms.Form)
at ZooAdmin.Wpf.Program.Main(System.String)
Any ideas?
