I’ve got a line that shows up as zero length when measured using Analyze/Distance but when I dimension it the distance shows up. So . . .
Better minds than mine are needed.
Hilary Smith Pacific NW PA 4-6-2 Loco SM Cab Roof Vent Test 1-32 2022-11-11 Distance Problem.3dm (1.5 MB)
Hi Hillary - the command line reports for distances and length follow the precision of the units setting pre file:
If you change that to decimal, you’ll see the expected distance. Better is to set the units in the Distance, Length etc reports as DecimalInches, then you’ll also get a more precise read and leave the document setting alone.
Thanks, Pascal. Not feeing particularly brilliant at the moment.
Hilary
