Zebra Surface Analysis
I’m trying to run a zebra analysis on a surface, and the resulting map is almost completely black, I can barely see the stripes. I’ve tried changing the object color, and cycling through different display modes, but nothing works. Any ideas? i use zebra analysis quite frequently and I’ve never seen this. The only difference this time is that the base model is from an IGES file.
Hi Adam- can you post the surface?
paddle srf.3dm (1.0 MB)
Hi Adam - in rendered display mode, use Flip to flip the normals and the convex side shows better, but in wireframe it looks OK here.
This appears to be fixed in V6.
that was it, thanks!
