What are the best program settings for a smooth Zebra image?
Hello - use the Adjust mesh button > Detaied controls and in that control set the Minimum initial grid quadsâ to some large number - 5,000 is a good start for individual surfaces.
Oh thats perfect, thank you Sir!
checking the âjagged seamsâ box usually helps tooâŚ
Iâm not so sure about that - with jagged seams, you can get a âfalseâ jag in the stripes as they cross the seam simply because the analysis mesh vertices do not line up.
With a fine enough mesh, it should really not be a problem either way - I had to work at it to get the above imageâŚ
Yeah, You are completely right.
I got the whole âjagged seamsâ nomenklatura upside down.
I re-formulate:
âun-checking the âjagged seamsâ box usually helps tooâŚâ, but that is the default, soâŚ
