I’m trying to install Weaverbird for Grasshopper but for some reason Yak is not working. It seems like Rhino 6 is blocking connection to the internet, but my internet is working and I’m running Rhino 6 on a zoo license. How to resolve this problem?
Unhandled Exception: System.AggregateException: One or more errors occurred. ---> System.Exception: Internet access disabled by Rhino
at Yak.Connection.<RunRequest>d__22.MoveNext()
Thanks for the extra details. I see that you’re using an Educational lab license… Is your computer managed by the school? Was Rhino installed by a system administrator?
You say that Rhino is connected to the internet. If you go to the “Update and Statistics” page in the Rhino Options (Help > Check for updates), is it all greyed out?
Based on the behaviour you’ve described, I think that Rhino has been installed on your machine using the DISABLE_INTERNET_ACCESS configuration setting. This installer setting is intended to be used by system administrators who wish to prevent Rhino from accessing the internet to check for updates, etc.
To fix this, you can upgrade Rhino, explicitly passing the default configuration setting. First, download the latest version of Rhino 6 (currently 6.25) from our website, then open up cmd.exe or powershell and run…
