Hi everyone! How do I perform this Y junction in order to keep the curvature continuity among all the surfaces? The diameters are different.
yjunction.3dm (2.2 MB)
You can watch this video tutorial and see one of the possible solutions. Of course, it shows the same diameter for the 3 pipes, but the same principle could be used in your case, too.
I would start by splitting the end pipes into 4 quarters each, then shrink each piece and rebuild it to degree 5. That will help with the subsequent connecting surfaces with degree 5.
Remember to always check the weight of the control points with the “Weight” command! If it’s any number other than 1, that will cause problems with the “Match surface” tool.
Place a point in the space where you consider to be the intermediate point between all 3 blend surfaces that you have in your 1st post. Then build curves that meet together in the exact location of the point.
And what about the green line? How do I create it? What line should I take as reference to blend with the middle isocurve he extract in the video?
As I mentioned, you can split your l the 3 end pipes into 4 quarters each. Then, you can extend the edge of the split quarter, but make sure to choose the “Merge=No” and “Straight” options. That will create a tangent extrusion starting from the split pipe.
You can extract an isocurve from the extrusion and is it to match the green curve to it.
I will show you soon. Just give me a bit time.
Another option is to extract some isocurves from your existing blend surfaces, trim away 1/3 of the surfaces, and then fill the resulting 6-sided hole with the new “Patch” tool of Rhino 9 BETA (if you have access to it).
Here is a quick workaround with the “Patch” tool of Rhino 9 BETA. I rebuilt the input surfaces to degree 5 with minimum amount of control points and fixed the weighted points, in order to get a clean geometry for the blend surfaces.
yjunction Bobi.3dm (11.6 MB)
And a video tutorial showing the whole process:
