XML problem but everything looks good
Hi All, @stevebaer, @clement,
I’m trying to read data from an xml file following the example found on Rhinopython forum:
import clr
clr.AddReference("System.Xml")
import System.Xml
def XMLTest():
    filename = r"d:\rosso.xml"
    xmldoc = System.Xml.XmlDocument()
    xmldoc.Load(filename)
    items = xmldoc.SelectNodes("data/items/item")
    for item in items:
        print item.InnerText
if __name__=="__main__":
    XMLTest()
at the execution of the line:
The script interrupt saying there’s a problem at row 1, position 44.
Of course rosso.xml exist at that position and it’s an xml file, could be because it’s a V-Ray material so without the standard declaration on the head?
here the source file: rosso.xml (4.0 KB)
and the original script: readxml_prova.py (339 Bytes)
Could you help me undertand what’s wrong?
Thanks!
Riccardo
Have you even seen the inside of the XML file you attached? It is full of binary stuff, not a plain text file!
It is definitely not an XML file as XmlDocument would understand…
Hi Riccardo,
yes, i guess the error message means that the xml file you´re trying to read is not having the proper header and therefore the encoding is missing. Look inside the file !
I´ve tried it in a xml text editor and Dreamweaver to check. Your script runs ok here if i use a different xml file.
c.
Thanks Guys!
This was exactly my suspect.
I’ll try to do it in another way.
Ciao
Riccardo
Yes… Feel stupid, I was looking to the code not taking care enough of the file !!!
With a Proper xml works fine.
SOLVED!
